Hello,
I am facing this error while running the process.
Python Scope: Error initializing Python engine
have a look on this thread.
Hi @Aastha_Singh
Kindly check your Path properties of the python scope.
It should be the location of python installed on your machine.
@Aastha_Singh
Kindly have look at the python activity process in this thread
Provided path are correct.
The execution of process running perfectly 4 to 5 times, But Now currently I am facing this Issue.
@Aastha_Singh
Try the path like as below
“C:\\Users\\username\\AppData\\Local\\Programs\\Python\\Python36”
Hello @Aastha_Singh
Can you please check whether any python update has happened? Also please check the below video.
Thanks
@Aastha_Singh
Try this Envinomental dynamic path
Environment.ExpandEnvironmentVariables("%USERPROFILE%\AppData\Local\Programs\Python\Python38")
And are you using the python 3.9 version?
I am using the python 3.6.2 version.
@Aastha_Singh
Are you using windows or Linux
If windows leave the library path as empty.
Above Version 3.9 or Linux only need to Give the library path
@Aastha_Singh
Kindly check your Path, It starts with “(” kindly remove it and try again
or
Look above dynamic path, after \AppData\ correct the path for your machine
@Aastha_Singh
Also check your working Folder
Working folder must be your project location.
Environment.CurrentDirectory
yes, working folder is in the project folder location.
If possible kindly send the path of the Working and app folder that you feed in the Python scope.
Also try this
- Check if your python is Updated or not
- Also check if your python is X86.
- Check whether Python is working or not? Open CMD-> Type “python” and enter
Try this
Environment.ExpandEnvironmentVariables("%USERPROFILE%\AppData\Local\Programs\Python\Python36-32")
