By set dynamic path:
Kindly open your python folder and check the folder.
Hi @Aastha_Singh ,
Was the Process Running fine previously as mentioned above ? If so, Could you let us know if there was any updates on the machine or the python version ?
Hello,
This process is running successfully, but after execution of 4 to 5 times this file is missing every time. This is the problem in this process.
File name: Uipath.python.Host.exe
Thanks
I already try this.
Problem is in the Uipath python package.
@Aastha_Singh , Open type cmd in search bar and open the command prompt
type-> where python
and copy the dirctory and paste as a path.
@Aastha_Singh
Try to run python by opening the command prompt
- type →
python
and enter - then type this
a=120
b=30
c=a+b
print(c)
my setting attached picture is running well, try to use simple code for testing,and make sure whether x64 or x86 system
Have the same issue… but on Python 3.9
Is there something wrong with my environment variables?
I’ve tried changing path in the properties of uipath activity to the same as C:\Program Files\Python39\
I’m not using anaconda distribution. Just installed python from the official site. The script works fine if I run it outside Studio…
I have the same issue as well with both Python 3.10 and now with Python 3.11 as I uninstalled Python and then re-installed the latest version.
Has anyone found a solution to this?
I was able to run python code after installing .NET 5.0.17 Desktop Runtime and by providing below settings for Python Scope Activity v1.6.0.
For Python 3.9.16:
Path: “C:\Users\USERNAME\AppData\Local\Programs\Python\Python39”
Working Folder: Working folder of the script.
For Python 3.10:
Library Path: “C:\Users\USERNAME\AppData\Local\Programs\Python\Python310\python310.dll”
Path: “C:\Users\USERNAME\AppData\Local\Programs\Python\Python310”
Worked for me - many thanks for the guidance
Can python scope activity initialize embedded python package ?
