When i run job in orchestrator it is going to pending state but not running. if i run attend then its running successfull and not in unattended more. i had enterprise license
When i run job in orchestrator it is going to pending state but not running. if i run attend then its running successfull and not in unattended more. i had enterprise license also.
Hi @MitheshBolla ,
Could you Check if there are Processes in Pending State.
all process i killed , when i start new process its going to pending state
@MitheshBolla Have you tried to open the VM and run from Uipath assistant?, you can also try to install the packages from local uipath inside the vm and start the job again
But i want to run job from orchestrator but not from assistant
@MitheshBolla Only for one time, try to run from assistant and also try to download the packages by opening uipath inside the VM, By doing this, all the dependencies will be installed. And now, we can try to run from orchestrator
in attened its running, but while running from orchestrator its not running
@MitheshBolla , I have faced same kind of issues before , It was either because the packages were not installed completely or Robot was disconnecting. you can try to disconnect the machine and re connect or remove the robot and re-provision again
