Is it possible to run a process in UiPath Assistant without publishing it to orchestrator? if yes?
how to do it? If no? What is the reason kindly help!
Yes you can run the process in UiPath Studio manually. No need to publish it to Orchestrator for it. If you want to run the process in any VM Machine or you want to trigger the bot you have to publish it to Orchestrator.
Open Project in Studio → In the design ribbon panel → You have the option called Run file → When you hit on it will run on the UiPath studio only.
Hope it helps!!
Sorry my mistake I want to run process in UiPath assistant.
