Laimis
(Laimis)
1
Hello, I’ve tried running my script in RDP (Virtual machine).
Everything works fine.
Problem:
When I minimized remote connection, robot stops working.
When I close remote connection, robot stops working.
As per checking it needs to keep open monitor all the time to make it work properly.
Maybe ony one has any solution for this, I don’t want to keep my remote connection open for 24/7.
Anil_G
(Anil Gorthi)
2
@Laimis
Welcome to the community
First while bot is running if you close it will stop…while running you should not close…you can signout before start so that bot logs in
For bot to run in unattended you need service mode installation and unattended license …
https://docs.uipath.com/robot/docs/robot-service
Also for running in minimized check this
https://docs.uipath.com/robot/docs/executing-tasks-in-a-minimized-rdp-window
Laimis
(Laimis)
3
Thank you, works on minimized ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
system
(system)
Closed
4
