Righ Click and Save As using UiPath
Hello,
I have requirement where download attachments from Web Portal . I need to Righ Click and use Save As option to save PDF/PNG/EXCEL documents from a Web Portal using Chrome. I am able to capture Right Click but I cant capture “Save Link As” through Manual Recording.
I tried below options and none of them worked
  1. Get Attribute and HTTP Request combination but it did not work. It saves output file in format that is not recognized by Windows.
  2. I tried using Manual recording right click and used F2 then tried to do the Save Link As , but manual recording does not recognize Save Link As click .
Any help appreciated.
Thanks
ramesh
Did you try click ocr text on save as button?
