I am trying to read a sheet which has no filter, its a simple table but the following error occurs.
i have tried with checked add header and without still the same problem
yes the sheet name is correct
Hi Can you upload or send screenshot of your activity.
Welcome to community
Check below for your reference
https://forum.uipath.com/t/tutorial-how-to-check-a-string-is-present-in-excel-sheet-part-1/243696/2
Hope this helps you
Thanks
