Problems working on work flows
I was using the UiPath community version and sometimes it doesn’t allow me to drag and drop activities in to the work flow. Then have to restart the whole machine.Even restarting UiPath Studio doesn’t solve it.Is that something to do with the machine performance?
Thanks!
Hi @Asiri
What’s the version you are using?
@Asiri
What version of studio are you using ?
Go to Help section and see whether are you using Alpha or Beta version.
Hi Lakshman,
These are the details from help, we are using an eval license on Enterprise edition for commercial use and its on 2019.4.2 and also having the same problem there.
2019.6.0 - 6/24/2019
Community Edition
EXE Installer
License Provider: Orchestrator
Device ID: ##################
Update Channel: Stable
Microsoft Windows 10 Enterprise 64-bit
.NET Framework Version 4.7.2
@Asiri
Could you please try to update it to Beta channel and then try once.
Hi buddy @Asiri
This is something strange, fine @Asiri
Click ESC multiple times…it works
Kindly have a view on this that could help you solve this issue
