Problem to read UI Element with Acrobat PDF
I have a problem with the interpretation of elements in pdf documents in Acrobat.
I have already had this problem and I have been able to solve it without problems. The problem happens on a new computer. The equipment has the same configuration in terms of reading options. The other does work properly. Both computers have the same version of acrobat (2021.007.20099) - 64 bits
Anyone know what the problem could be?
Thanks!
Hi @Gianfranco_Drago
Please have a look at this thread.
Hope this will be helpful. Thank you.
I have already tried to configure the reading options according to the version indicated in the guide. I clarify that it works for me on one computer, and not on another. I do not know the problem.
Thanks!
The accessibility/reading options should be aligned on all the machine that we are planning to trigger the BOT.
Look into this thread as well.
Thank you.
I found a new problem. In UiExplorer, when I try to capture icons on the windows screen, you can’t detect them. Why is that?
Thanks for the help!
Going forward kindly create a new topic for new issues.
Please change the ‘UI Frameworks’ in UI explorer and try to indicate the element again.
Thank you.
Thats work! Thanks.
Now the problem is partially resolved. I have this situation:
I need to extract the data from that field. The field element works on my other computer. But not on the new computer.
I am still stuck with this and it is essential to solve it .
Thanks
Please do this.
Kindly mark the relevant post as solution for the ‘[Problem to read UI Element with Acrobat PDF]’ issue so that it will be useful for others as well.
Thank you.
