Kindly help/guide for following mentioned error message displayed at trying to run Orchestrator → My Workspace → Automations → Triggers. Error message screenshot attached herewith.
Error Message : “There are no Testing runtimes configured on this machine.”
Hi @Webotive_Cloud ,
Could you Check the Type of License allocated for the Robot?
You might need to either change the License Type or Increase the License number.
Gokul001
(Gokul Balaji)
March 21, 2022, 4:42am
3
Hi @Webotive_Cloud
Welcome to community
Can you check the type of License and Robot
We have two separate robots setup to run on one machine. (1 unattended license)
We currently have an issue where after robot 1 has finished processing a Job, if robot 2 tries to run next I get the below error even though robot 1 has finished.
Info: Robot Licensing Failed. There are no available runtime licenses. (#1915).
It is like robot 1 isn’t releasing the license properly so it can be used by another robot after completion?
Has anybody come across anything like this before?
Thanks, …
The UiPath Documentation Portal - the home of all our valuable information. Find here everything you need to guide you in your automation journey in the UiPath ecosystem, from complex installation guides to quick tutorials, to practical business...
https://licensing.uipath.com/
Regards
Gokul
HI @Webotive_Cloud
Welcome to Community !!
Have you configured runtime in orchestrator?
Regards
Sudharsan
Hi
Welcome to UiPath forum
Have a view on this thread for steps to be followed
UIPath Test Suite - Not able to see the Testing related options in uipath orchestrator.
Can someone please help me on this.
[image]
Cheers @Webotive_Cloud
