until now, i still don’t see any topic that guides on how to easily embed an image in html email bodies. i honestly believe that this should be a basic activity that is supported in uipath.
there are some posts and 3rd party packages, they are helpful so far, but if a company does not want to use those 3rd party packages, there are no other easy option to perform this.
I found out that if I gave the ContentId the same name as the document without the path, the it worked for me.
Image=“C:\Temp\test.png”
ContentID=“test.png”
Hi there, did you test this between different mail servers? ie. Sending from Outlook, but receiving email in Gmail? I have the issue where this does not work no matter what method I have tried. Be careful that these images are only appearing on the same platform you send from.
