Filter data in excel with Type = WI1 and open each work item for WI1 I page 1 using loop
Need to click on this search option but it is not taking suggest a next step after doing filteration of data what should I take?
Please use for each ui element it has inbuilt filter as well
To get data use extract table data
And then add column to datatable and update datatable and then write to excel
Thanks for the reply I have done that but after I have to click on specific for updating that I am not able to do
are you using for each ui element? for each ui element has nothing to do with excel
now coming to identifying ..you need to indicate full row in for eahc ui element..inside the loop use find children to get the search icon selector and use the output to click on the search icon
also using another find children you can also get other column values
cheers
cheers
Dear @tanya.ojha,
You can use below steps to done the work.
3: Use click activity to click on search icon. Use item type as anchor in the activity as follows:
Mark as solution, if it solves your issue ![]()
Br,
NikZ
Use Find Element or Element Exists with a dynamic selector that contains the current WIID to find the correct row.
Example: Use a selector like "<webctrl aaname='"+currentWIID+"' tag='TD' />".
