Click issue for specific number
Hello,
I’m having another issue with my automation (it is my first automation).
To give a brief explanation, the bot will add two filters to this website, and click search. When the results appear, I need to bot to click on the number under “Invoice”, this number will be for every search. When I use the click activity and put the target at the number, if the number is not the same, the bot won’t click anything, but if I put the target to be around the number, the bot won’t click because it needs to click on the number. Any sugestions?
Hi @NathaliaFawcett
We need to make it dynamic so it will click irrespective of the number. Can you please put the selector screenshot of this click activity on the number.
You can include wild cards (* or ?) in between your selector to represent changing values.
This is what I have right now
@NathaliaFawcett it will be something like this
<html app='chrome.exe' title='Search: * - Console' /> <webctrl aaname='"++"' tag='A' />
Before you click on confirm after indicating the click
button activity in the right side panel you can see the selector strict selector, fuzzy selector
I was able to do it. Thank you so much for your help!
