Click BRL: Click with "Simulate" is not supported for this element. Please use other input method
Click BRL: Click with “Simulate” is not supported for this element. Please use other input method.
I’m having this problem in SAP
Go to properties panel for this activity and set SimulateClick property to false:
Let un know if this solution works
Hi @pauloengenharia5 use sendwindow message or false both the properties i.e sendwindow message and simulate click and try…
I didn’t understand very well, would you have an example of this activity
In properties panel make send window message to
True or false or both false
Try with all
Instead of click activity you can try with Click Image activity
Check out this document
Regards
Gokul
