Click with "Window Messages" is not supported for this element
Hello All,
A user is getting the error: “Click with “Window Messages” is not supported for this element. Please use other input method.” However, only one user gets the error. When I run the process on the same desktop and same version, I don’t receive the error. Has anyone seen this issue before?
Hey @PWilliams
So is it all the same app version, machine config and UiPath versions ?
Thanks
#nK
Hi
Try disabling sendwindowmessage property and enable simulate click property and give a try
@PWilliams
Hello @Nithinkrishna
Yes, everything is the same.
Hello @Palaniyappan,
Thank you for the suggestion. I will try it if I can’t find out why its not working for only one user.
