I am new to UiPath and trying to learn this new tool (Thanks to UiPath and UiPath Academy). I am stuck at Calculate Client Has Security.
When I run mail.xaml, It goes fine till login to system1 ( i can see the login "dashboard’ Page), but after that it does not goes to next work flow (i put message box after system1 login xmal it is not displaying that message) instead it click on logout and close the explorer.
But the problem is, login to system 1 is successful. After that it should execute next work flow of clicking work order but it does not moves further instead throws the error , not sure why it call sendmail.xaml when the login is successful .
Have you used a IF condition to check whether the login is successful and only call the send mail if it’s not successful?
About the send mail, try the smtp port 587. Also make sure you have enabled smtp in your gmail account through gmail account settings. Otherwise it will not work.
I believe that should solve your email problem. On the other hand, by looking at the two errors I notice that you have some selectors that do not work in closing applications state. Specially the SHA1. Make sure those selectors are fixed too
Thanks, I am attaching the screen shot of sendmail.xaml and also attaching login xaml file for reference.
By the way can you please let me know which selectors do not work in closing application ? Sorru I am very new to UiPath and not from developer background so :(.
I go through your login workflow
1)remove find the element activity its return Ui Element .i think there is no need of this
2) pass LoginSuccessful variable in Exist Property of Element Exist Activity
Thanks a lot Sandeep for quick response, After I set the output to “LoginSuccessful” the error gone. After this it does go to work Item tab and follow the workflow to extract work item data table. And then just terminate the process instead of closing system 1 login page.
How can I check the extracted data table to see if it has collected the data or not?
For above suggestion from you on login xaml I did not see app for selection i tried with Uipath explorer too.
To check the value of the extracted data table .you can check the count of row in data table in INIT section or you can check same way in System1_Extract_WorkItem workflow also out_WorkItems.Rows.Count
To terminate the process concern check the output panel for the exact error.
As per my experience error should be in the system1_Close workflow selector
I am not sure if it is coding/workflow issue or browser issue. I am facing weird issue. When I try to run Main.xaml file system 1 login will success full the it will click home button and then instead of clicking workitem tab it will click logout. After I try multiple time it will work fine automatically and workflow moves further till I faced problem I posted just now.
The output I see when it logout immediately without going to work item is as bellow.
hello @ManojSomani
the reason could be different browser/page of acme site will open instead of ‘ACME System 1 - Dashboard’ page. so exception occurs then flow goes to end of process section where you called close application workflow
Sorry for late response. No it is always the same page when it works and when it does not works. Also some time my username (Email-id) does not get entered correctly (Correct Emai-ID is somani_manoj@yahoo.com), screen shot of same is attached.
So i am guessing it may be IE browsers issue. Is there any easy way to search for browser/application IE and replace with Chrome to check if it is browser issue?
