Have anyone had experience working with an application “OE Premium System” as shown below.
It looks like a AS400 terminal from first glance, but is not.
As expected using the indication (even with UI Explorer as well) unable to get a readout within the framework
To try with CV Vision, I believe it may not be efficient as it will be slow and the steps are heavily dependent on Arrow Keys, FN keys and get screen text (very similar to terminal concept)
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
I cannot find any references on the internet regarding OE premium. Can you share any other information regarding the terminal and how the connection is configured in the terminal?
Anyway, to me it looks like a unix-like system. So VT or ANSI type terminal, with Telnet or SSH as communication protocol might be an option.
As for retrieving the text from the OE terminal window what I would try is:
Get Text activity (UI automation)
Get Visible Text activity (UI automation)
Some way of getting the terminal content in the clipboard, some HotKey combination, perhaps a context menu item.
Then use string processing (split/substring) on the whole text to get to the values you require.
Thank you for your reply.
I did checked with user to get more details, here is what I obtained
The program OE - in a OpenEdge Progress Software
This framework already been use for more than 20 years
On the network communication, the info i manage to get is how the program is launched:-
C:\PROGRESS\OpenEdge\bin_progres.exe -pf C:\SST1\PREMIUMP.PF -TM 31 -TB 31 -Mr 15000 -l 8000 -basekey “INI” -ini C:\SST1\PROGRESS.INI
It is probably very consistent in where things are positioned on the screens, much like a mainframe. So you should automate like a mainframe - keyboard commands, etc.
If you can’t get text from the screen then OCR may be your best bet.
Yup, i did thought of that
The objective of the process are to data entry and send keyboards an FN keys much like a mainframe. but unlike mainframe where you can specify the entry using coordinates, this doesn’t have any coordinates to begin with.
Also user tends to enter in various locations which pretty much complicated to pinpoint even we are able to use OCR to capture the content
Thanks for the details. The documentation confirms that it’s a unix-like system but the launch sequence does not provide any information on how the connection is made.
I would suggest to automate the OE screen with keystrokes, just like a human user would use the application.
For retrieving the data from the screen, I understand that you tested UI Get Text, but from personal experience, UI Get Visible Text works in cases when Get Text doesn’t.
If Get Visible Text does not work, there has to be a way to copy the data from the screen into the clipboard (a menu item or a hotkey combination). Then use the Get From Clipboard activity to retrieve the text.
