Hi everyone,
When installing robots on a virtual machine, I do face problems.
For instance, click image activity does not work, even click activity sometimes.
Are there any impact of virtual machine on robots?
Thanks,
Hi everyone,
Thanks,
Hi
Kindly enable simulate click property and try once
Cheers @Youssef
This is similar case.
I assume click image using desktop image so if your vm is not visible from UiPath, it will be failed. So you need use simulate click / send window message to click something. otherwise you need open vm with full-size window on your desktop.
