Please assist.
I already tried changing project name, solution name, location, place solution and project in the same directory checkbox, uninstall and reinstalling Uipath activity creator, visual studio reinstallation. No luck.
Hi All, I got this fixed. If you are getting this issue please use the attached vsconfig file and installed the requirements.Please remove the .txt from the file I attached and go to visual studio installer. Under more option select import configurationa dn select the vsconfig file. You will getvsconfig.txt (1.8 KB)
