Hi team ,
I want to use the same machine for developing code as well as running unattended automation . I have 2 licenses - automation dev and unattended production. What changes should I do to the UiPath studio to enable this?
Gokul
Hi team ,
Gokul
Hi @gokul1904,
Once you are done with developing automation, To switch to unattended setup, follow below steps:
Regards
Sonali
Hie @gokul1904 for running your process in unattended mode you have to setup unattended robot in UiPath Orchestrator and add your machine so you can run your process in unattended mode.
kindly follow these steps to setup unattended robot and add machine template :
Configure UiPath Orchestrator
3. Configure UiPath Robot on the Machine
Hi
Normally Automation Dev license is assigned to developers which could not be used for unattended setup.
If you want to run in unattended mode - I would suggest to have one machine with unattended setup for all the developers to test after development.
