Hi everyone,
I have developed a workflow using studio that logs into an application/web page, queries an invoice and if found, downloads and saves it to a network share folder. It works fine when i run this on my local machine in studio ~~ However, if i publish this to orchestrator and attempt to run the same on a remote server, i get as far as the save-as dialog box. What could be the reason why it’s not running successfully on the remote server, assuming that IE is the same version running on both machines for example?
Thanks for any help.
