Is there best practice example for creating process flows in the Design Specific Document (DSD) or PDD, the as-is and to-be flows generally. I do not assume that people are drawing activity by activity on the process flow on ‘draw.io’ or somewhere.
Drawing process flow diagrams for As-Is & To-Be process will definitely help the process visualisation & people often use draw.io as it’s user friendly. It’s not a mandatory rule as such, but it’s one of the best practices to prepare them.
You can either use UiPath’s Task Capture, which automatically prepares the process documentation for you & modify it accordingly or you can refer the following component for the same:
