Hi guys,
In our robotization of different processes we are faced with problems that prevent us from moving forward.
The most relevant is that when processes are shared between different versions of UiPath, the processes do not work, neither when we re-programming them.
For example, I leave a simple process to check if there is network on the computer and in the version of UiPath Studio 2017.1.6522 Community Edition and 2018.1.4 enterprise edition the process does not work while in version 2018.1.3 enterprise edition yes.
On the other hand we have detected that the same thing happens with screen scraping, in some versions it detects selectors like UiElements and in other versions it does not. Someone knows how to solve these problems, because they cause delay in robotization and do not give us security with the tool.
We enclose the simple process for you to review.
Main.xaml (8.0 KB)
We solve the problem!!!.
It was on virtual network that showed up in ethernet window.
We did not have the networks activated except for a virtual one. So it detected an available network.
Hi
i have same on version its not open .xaml file .
what should i do.
