Hi Team,
I am facing issue while reading a file using workbook read range.
Please see the image for more clarity.
Looking forward to your response,
Pankaj
Hi Team,
Pankaj
Hi @Pankaj_Yadav,
Can you send the screenshot of the activity in studio (the part of the excel scope)
Hi @vmariejeanne thanks for your response, i am using Workbook read range, not using the excel scope
Hi @RachelN,
Please find the same.
Thanks
Is the read range working properly when u give some range like “A1” or “B1”??
Hi @RachelN and @vmariejeanne, thanks for your response
i am using the excel scope and it is working with it, but i dont know why it was not working with workbook.
Pankaj
Hi! @Pankaj_Yadav Wich Version are you using? I just update the new one and also is not working read excel any of them
I’m not sure, is it because the Read Range activity was stripped of the workbook path field in the update?
From 3 blocks of input down to 2 blocks
Check here
