I have orchestrator running a robot which should add an attendee to an event I have already created with the google account I set in UiPath Studio, but when I run the robot it opens a webpage with a 400 error: redirect_uri_mismatch.
If someone could walk me through how to correctly use the UiPath with GSuite integration so I could replicate it, that would be great.
To resolve this issue
kindly have a view on this thread buddy
Upload to Google Drive Folder
For more insights on GSuite Hope this could help you buddy
https://go.uipath.com/component/google-gsuite
Cheers @David_Lifschitz
hi,
i’m still confused how to fix my particular problem.
the error specifically states this:
“The redirect URI in the request, http://localhost:58060/authorize/, does not match the ones authorized for the OAuth client. To update the authorized redirect URIs, visit: https://console.developers.google.com/apis/credentials/oauthclient/973744586116-fccl9nt7ai8g7mbek508p6j5n9a1hn3v.apps.googleusercontent.com?project=973744586116”
I think the problem is that I can’t authorize a URI because this section, closed in parentheses, http://localhost:(58060)/authorize/, is randomized and therefore I cannot use one because it always changes.
I have no idea. what would cause the access port to be dynamic?
What i do know is that each time I make a new job using the robot it uses a new access port.
