Problem in UiPath Studio Installation
Good Day.
I am trying to install UiPath Studio. However, after the installation of the UiPath Studio automatically converted into StudioX and I could not change it back to UiPath Studio. Is there any solution to solve this one without changing the organization name in the cloud? Kindly see the picture below. Thank you.
Best regards,
Robert
Hi @RobertRussell_Monsalud
I think you have used the enterprise trail Pro edition, when it expires the UiPath Studio will directly change from Studio to Studio x.
→ In this case, you have to change the organization name in your profile. After you installed the Studio after that you are logging in, it will ask for organization name change the organization name then it will give the access to UiPath Studio.
Note : After you changed the Organization name you are able to access UiPath Studio but you can’t again use the Trail Pro edition.
Hope it helps!!
What kind of licence you have?
Check out this thread this will help
Hi @RobertRussell_Monsalud ,
Please refer following document to know about UiPath studio installation.
Studio - Install Studio (uipath.com)
Also make sure that you have assigned UiPath Developer license to the user which you are login.
Yes, I have used an enterprise license before but right now I am just using a community edition. If ever, how to change the organization name?
Okay @RobertRussell_Monsalud
When you change the Organization name for the same account the new Orchestrator will appear and you have to create new assets, queues and other data.
Note : But you can’t use the Pro Trail version once more.
We recommend you to create a new Account with the new mail ID then you will directly logged into Community edition and you will get the Free Pro trail.
Hope you understand!!
