Dear Forum Members
When i am entering input in Rate mentioned in image getting data from excel it is changing selector and input got entered in Quantity .
Anyone can help ?
Any Suggestion or comments will be appriceated .
Thanks
Dear Forum Members
Anyone can help ?
Thanks
Hi @Sahil_Garg
Can you share the error that you’re facing?
But what I assume is there maybe an id value in your selector try removing the id value from the selector.
Aditya
Hi desineediaditya
The error is instead of entering value in Rate it is getting entered in Quantity
Hi @Sahil_Garg
Have you checked the selector? is there any idx related value?
Aditya
Yes but it is needed if new row is added
Hi @Sahil_Garg
Can you share the screenshot of those two varying selectors?
that helps to understand your query better.
Aditya
While selecting Rate
Hi
It was just an index issue the index which is assigned to Rate is different
Thanks for you response
