I have an application where it will prompt for credentials
In IE the pop-up is as shown in below pic
Whereas in edge -
Here my issue is, I am able to get selectors for pop-up which is present in IE but I am not able to get selectors in edge browser.
Ui explorer is not detecting pop-up in edge.
Thanks in Advance
Hi @Kondagari_Mounika
Are you able to detect other elements on Edge.
Thanks
Hi Suraj,
I am able to detect other elements in edge, I have uipath extension enabled.
Thanks
Please let us know if you are able to detect Sign in button or the username fields on the pop up?
Thanks
Not able to detect neither text box or sign in buttons
Is it possible to share the link?
Thanks
Can you try with Image Automation like “Click Image” and “Image Exist” activities. If that would serve the purpose.
Thanks
Hey!
You’ve installed the IE-Extension right.
Could you please reinstall the extension from studio and try it again…
And also clear the cache from the Edge
NaNi
@koundagiri_Mounika
Were you able to resolve it. I am currently stuck with the same. Tried ‘Application broswer, send hot keys, keyboard shortcuts’ nothing worked. Even dev tools isn’t able to detect the pop up
use one more application/browser to handle the popup
and also use hardware events in it
Regards
