AryanSingh
(Aryan Singh)
1
@Palaniyappan
Hello Guys
I am trying to add same queue items again on the queue. But not able to add them.
It is working with other queue properly and workflow is the same.
Please check the screenshot below ::
Error Creating Transaction. Duplicate reference error. Error Code: 1016
Always facing the same issue.
ADQueue Add Item.zip (1.6 KB) Test.xlsx (9.3 KB)
Thanks and Regards
Aryan
Are we trying to create a same queue item name in that queue
cheers @AryanSingh
AryanSingh
(Aryan Singh)
3
@Palaniyappan
Yes so the reference will also be the same!
Sreelatha278
(Sree Latha Reddy)
4
@AryanSingh
While creating queue if unique Reference is set as Yes then it wont allow you to add duplicate value.
Fine
Kindly have a view in this thread pls
Cheers @AryanSingh
AryanSingh
(Aryan Singh)
6
@Sreelatha278
Ohk, I thought that my previous Queue was set to unique reference. Sorry. I think its solved.
Thanks and Regards
Aryan
system
(system)
Closed
7
