Hello UiPath Community,
I hope this post finds you well. I am currently facing an issue with the Screen Scraping activity, and I’m reaching out to seek your valuable insights and solutions.
After performing the Screen Scraping activity on a particular application, I have noticed that values are not being extracted for some specific fields. The issue seems to be inconsistent, affecting only certain fields while others are scraped successfully.
This is the line item for which screen scraping was done
- Fields Affected: Allowance/Charge, Amount, Percentage, Method Of Handling Code.
- Screen Scraping Method: Fulltext.
- Observation: After the Screen Scraping activity, values for the mentioned fields are consistently not being extracted.
Screen scraped text -:
LineNo1
AllowanceCharge
AllowChargeCode1
Amount
Rate1
Percentage
MethodOfHandCode
Description Line No.Allowance / ChargePercentageAllowance/Charge CodeAmountRateMethod of Handling CodeDescription 2
Your insights and suggestions would be immensely valuable in resolving this issue. If additional information is needed or if there are specific details I should check, please let me know.
Thank you for your time and assistance!
