Hello,
In order to build my first automation, I am trying to read each column activity in excel and try to find each cell value excel and then find its position on an SAP screen in order to perform a click.In order to do this, I am trying to assign the read column output as a variable and then use it in for each loop, but the issues I am facing are-
the output variable in read column is IEnumerable which I am not able to convert
Difficulty to figure how to make UIpath read the value output and search it on SAP screen.
Welcome to uipath community buddy
Thats a good question to start with
Fine
kindly find the below activities that could help you buddy
Use excel application scope to open the excel and pass he input as file path of the excel
Use read range activity to read the data inside the excel and use it inside the excel application scope, pass input as sheetname, and range “” and get the output named out_dt which is of type datatable
Once after this use a for each row loop to iterate through each row by row and use a assign activity like this buddy
outcellvalue = row(0).ToString
where outcellvalue is the variable that stores each cell value row by row in column 1 which is here mentiond as 0, as the column index usually starts at 0
like wise you can take any column you want to iterate through each row by row @shay
either by mentioning the column index or even columnname buddy like this
outcellvalue = row(“columnname”).ToString
once you find this you can go to SAP buddy and use click activity and type into activity with the above variable as input that would enter the data to the respective fields buddy
Thats all buddy you are done
Kindly try this and let know buddy
this can be easily resolved buddy @shay
