It takes same hash code for same thing again and again. How can I solve it. Thanks in advance.
Ay my first glance you are pasing index in the array that are exceed in the count of array.
Can you share more details like puting some screenshots where the error occured. @Hasna_Hoque_Mitu Thanks.
cheers
Happy learning
Thanks a lot for your response.
I actually don’t know where exactly the problem is! It is taking only the hash code of that thing which I used as sample in the project.
It’s showing that the problem is here.
@Hasna_Hoque_Mitu my guess is that there’s a problem with your WIID values, I think the workflow is only loading the 1st WI5 and not the rest.
Try debugging the workflow, you should see that after each transaction the WIID url changes.
@Hasna_Hoque_Mitu please use (in_TransactionNumber-1) and make sure that you’re using the correct argument names.
After seeing your solution, I used that.
Try changing the values for Assign TransactionID to
out_TransactionID = out_TransactionItem
@Hasna_Hoque_Mitu my bad I didn’t notice that I placed the incomplete values
it should be:
out_TransactionID = out_TransactionItem(“WIID”).ToString
yes, I’ve already put out_TransactionID just like that
Can you please upload you GetTransactionData xaml file?
I’m having the exact same issue as @Hasna_Hoque_Mitu - my xaml is attached.GetTransactionData.xaml (8.8 KB)
Whenever I want to upload “Get Transaction Data.xaml” file it shows this.
May I have your email address so that I can send you the file?
Hello @AceRenegade please try changing the value of your first assign activity in the outer if statement. Change it to:
out_TransactionItem = in_WorkItems(in_Transaction_number-1)
Also, what are you using the “out_workitemnumber” argument for?
