This is the configuration file: default.json:
"server": {
"host": "127.0.0.1",
"port": 6543
"orchestrator": {
"hostname": "platform.uipath.com",
"tenancyName": "xxxxxxxx",
"usernameOrEmailAddress": "xxxxxxxx",
"password": "xxxxxxx"
"dialogflow": {
"private_key": "xxxxxx",
"client_email": "dialogflow-gajivq@demochatbot-aatnep.iam.gserviceaccount.com",
"projectId": "115556440368131734996"
UnhandledPromiseRejectionWarning: Error: ERR_OSSL_PEM_NO_START_LINE undefined: Getting metadata from plugin failed
with error: error:0909006C:PEM routines:get_name:no start line
at Object.callErrorFromStatus (D:\xampp\htdocs\chatbot\node_modules\@grpc\grpc-js\build\src\call.js:30:26)
at Http2CallStream.<anonymous> (D:\xampp\htdocs\chatbot\node_modules\@grpc\grpc-js\build\src\client.js:96:33)
at Http2CallStream.emit (events.js:214:15)
at D:\xampp\htdocs\chatbot\node_modules\@grpc\grpc-js\build\src\call-stream.js:97:22
at processTicksAndRejections (internal/process/task_queues.js:75:11)
(node:13808) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
(node:13808) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Please let me know if there is any solution for this, we stuck here.
Anil Kumar Bandam
