Hello everyone,
I need your help regarding a problem scenario I am facing.
Currently, I am working on uipath orchestrator and third party dialogflow chatbot integration, for this I am using node.js connector to connect both sides uipath orchestrator and dialogflow chatbot.
The steps for user to chatbot to orchestrator executing the task are as follows:
Step 1 : The user enters the query.
Step 2: The dialogflow matches the query with the right intent and sends the json payload in v2 api format to the node.js connector.
Step 3: The node.js bridge then sends http post url request to the orchestrator with the required parameter for task execution and starts the orchestrator.
Step 4: The orchestrator first login into platform.uipath.com and updates the queue specific to the user query request.
Step 5: The orchestrator then executes the process and returns the response back to the node.js bridge.
Step 6: The node.js bridge then forwards the orchestrator response back to the user.
Downloaded node.js connector from uipath go.
Previously before the login screen changed the connector was working fine only for one stage where the orchestrator queue was getting updated but the task was not running and so there was no reply back to the bridge and hence to the user.
My current problem is this that the orchestrator login UI has changed completely and so the node.js code has become redundant as the orchestrator is unable to login to platform.uipath.com .
The authentication process will completely fail with the new UI screen.
Previous Screen:
The previous screen requires three parameters: 1. Tenancy Name
Email Address
Password
New Orchestrator login screen:
The new screen is missing tenant name and the orchestrator cannot login with just email and password.
The whole automation is stuck to this point only.
Moreover the orchestrator inner tabview screen has also changed.
The new console has no options for queues and processes and hence the orchestrator will not find the necessary task to execute and hence the process will fail.
Moreover the node.js bridge code is written in v1 api format which is going to be expire in October 2019 as per google docs.
Please tell me how to solve the issue regarding screens changes both on login as well as inner tab views.
The orchestrator cannot run the queue if it does not find the queue option and process to excute the task.
Thanks,
Akash
