Thanks for your reply. When I reinstall the Uipath extension for Edge then it works.
However, after each restarted of my laptop, It doesnt work and I’ve to reinstall again the Uipath extension for Edgem and then it works again strange.
I dont want to reinstall the extension after each restart, could you please help?
Do you know which services is linked to this extension? maybe then I can check with my helpdesk department?
After restarting my system and running my automation in PIP mode, I don’t get an error message.
The problem is that I can’t double click on the “Edge” shortcut icon located on my desktop.
and that cause issue at the middle of my automation.
However, strange => when I double click on Chrome shortcut icon, then it works (see below):
Could you please let me know what can cause the issue?
No need to pin the edge to task bar or no need to double click on the desktop icon. this will start the application even if you’re system restarted or updated.
Yep I already use the open application activity but in the middle of automation I ask the robot to open an ouptut file from our ERP and then it open Edge page and at this moment the automation fail.
but I was able to solve my problem after unclicking both below options under Edge settings.
