Hello, I have a problem that when I open Edge in PIP the UiPath extention in disabled.
Can any body help me with this? the robot works fine if a dont use PIP.
Hi @tomaz
Open Microsoft Edge and go to the Extensions settings by typing edge://extensions
in the address bar. Look for the UiPath extension and toggle on the “Allow in InPrivate” option. Additionally, you can try enabling the “Developer mode” option at the bottom left corner of the Extensions settings page.
Thanks!!
