How to manage Automation Hub as a separate Tenant?
We have several Tenants by for different Business units on Orchestrator Cloud. Now we want to create separate tenant for Automation Hub for one business unit. Which should not have access to any other tenant. We may assign one admin for that AH tenant and he/she should not have access to other than that tenant only. I created one dummy tenant with AH and created sample admin account, but with that account I can see all the user groups from other tenant. I want to isolate this tenant completely from other tenants due to privacy issue. How can we do that?
Just to give little background: This automation Hub license is purchased by other business unit but under our orchestrator account. And it should be managed by that business unit only.
Hello @hbunha!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
  1. Always search first. It is the best way to quickly find your answer. Check out the image icon for that.
    Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
  2. Topic that contains most common solutions with example project files can be found here.
  3. Read our official documentation where you can find a lot of information and instructions about each of our products:
  4. Watch the videos on our official YouTube channel for more visual tutorials.
  5. Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
