How to get request by using variable in the body of HTTP request POST?
Hi everyone
I am trying to call an API using HTTP request by using Json
there are 3 variables in the body which are : idm, ids and idl
“{ ““productId””: “+idm+”, ““entityId””: “+ids+”, ““code””: “””+idl+“”“,”" heritages"“: }”
When I do the POST request, the call use always the last value of all theses 3 variables.
exemple:
variable idm can be 1, 2 ,3
variable ids can be 1, 2 ,3
variable idl can be 1, 2 ,3
the result that I’m looking for is that robot will call 3 times with 3 different requests
{ productId: 1, entityId: 1, code: “1”,heritages: }
{ productId: 2, entityId: 2, code: “2”,heritages: }
{ productId: 3, entityId: 3, code: “3”,heritages: }
However, I got only one request of the last value which is
and the robot continue to post the same request.
Thanks for the help,
Ze
Hello @zeee!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
  1. Always search first. It is the best way to quickly find your answer. Check out the image icon for that.
    Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
  2. Topic that contains most common solutions with example project files can be found here.
  3. Read our official documentation where you can find a lot of information and instructions about each of our products:
  4. Watch the videos on our official YouTube channel for more visual tutorials.
  5. Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
Hello Zee,
Check out this very fast simple VB.NET that create JSON in 1 line:
startUiPathFromSalesforce/CreateJSON.txt at master · cristinegulescu/startUiPathFromSalesforce · GitHub
And the movie for demo:
Thanks,
Cristian
