I want to implement a series of Excel operations in coded automation(coded workflow). Do you have experience in this area? Thank you!
Why do you want to go for coded automation ?? You already have all the excel related activities right?
I just want use coded automation to complete excel-related operations, rather than drag the excel actvities.
Ways to get started:
Example one:
var dt = new DataTable();
var readWorkbook = new UiPath.Excel.Activities.ReadRange();
readWorkbook.WorkbookPath = @“C:\Temp\temp.xlsx”;
readWorkbook.SheetName = “Sheet1”;
readWorkbook.AddHeaders = true;
readWorkbook.PreserveFormat = true;
readWorkbook.DataTable = new System.Activities.OutArgument<System.Data.DataTable>(context => dt);
WorkflowInvoker.Invoke(readWorkbook);
Example Two:
System.Data.DataTable dtOutput = new();
WorkbookPath = @“C:\Temp\temp.xlsx”,
SheetName = “Sheet1”,
AddHeaders = true,
PreserveFormat = false,
DataTable = new OutArgument(ctx => dtOutput)
Example Three:
var result = WorkflowInvoker.Invoke(
AddHeaders = true,
PreserveFormat = true,
var dtOutput2 = result[“DataTable”] as System.Data.DataTable;
FYI - when getting an error like
System.Activities.InvalidWorkflowException:
'The following errors were encountered while processing the workflow tree:
'Literal<UiElement>': Literal only supports value types and the immutable type System.String.
The type UiPath.Core.UiElement cannot be used as a literal.'
Then do this for the arg causing the error
WorkflowInvoker.Invoke(new NClick
OutUiElement = new OutArgument<UiElement>(ctx => ele_out_ClickedElement),
ClickType = bln_in_DoubleClick ? NClickType.Double : NClickType.Single,
MouseButton = NMouseButton.Left,
CursorMotionType = CursorMotionType.Instant,
InteractionMode = NChildInteractionMode.HardwareEvents,
ActivateBefore = true,
KeyModifiers = NKeyModifiers.None,
InUiElement = new InArgument<UiElement>(ctx => eleForClick)
Depending on what you want to do, a lib called closedxml may be what you are looking for.
