Hi masters, pls help me in solving this issue. Facing error while running process from orchestrator
This is the error:
Info: Could not load file or assembly ‘UiPath.IntelligentOCR, Version=6.7.0.0, Culture=neutral, PublicKeyToken=null’.
The system cannot find the file specified. System.IO.FileNotFoundException: Could not load file or assembly ‘UiPath.IntelligentOCR, Version=6.7.0.0, Culture=neutral, PublicKeyToken=null’.
@Lokesh_M2
On the target machine where you are trying to run the bot is unable to find the required library to download
You can either copy the library from any other machine /Dev machien may be to the .nuget folder on the prod machine…
Else check if the required feed is added in your orchestrator
cheers
Check with your network security team to see if the server is blocked from accessing the package feed.
