Hello UiPath Community,
I’m new to this tool and there are many things that left me confused. I was doing a demo practice, opening a Notepad++ and typing in some text.
So everything worked normally at first, when the txt file was empty. However, when I have inputted some text before and played the robot again. The process is stuck and there is an error.
Can someone kindly explain to me why an empty txt file works while the nonempty file does not work?
Edit: Sorry for the post. I have already found out the problem. My text file was not saved after the first try, and the unsaved status remained even after I closed down Notepad++. This prevented the robot from making any further input. If I save the document and close it again, the robot works normally.
