Hello
I use UiPath community edition, searched for the answer on the forum, but did not find anything
I do so and everyone says it’s right.
PROBLEM: after the correct way of typing a hotkey, a letter is entered in the document. CTRL the code is clamped and active after the end of the workflow, that is, after the end of the project, I scroll the mouse ball and I change the scale in the program of the studio
When I add a special key (gives an error)
Help me please, the success of my project depends on the solution of this problem
Main.xaml (14.3 KB)
Can you attach your workflow.
You are not yet uploaded…
Attach the file…
@MahalingPatil
Hello
for_forum
Help me please, the success of my project depends on the solution of this problemMain.xaml1 (12.3 KB)
I do not know why you do not see it.
@Kirill_Kubskiy, Its working as expected ! But you have missed out CTRL+C to copy it before you use get from clipboard if I am not wrong.
Dom
@Kirill_Kubskiy, Screenshot . Can you check with the same xaml that you have uploaded ? You might have made some changes (while playing with the properties ) I guess.
Dom
@Dominic @MahalingPatil
I need him to select all the text and copy it, but the hot keys do not work
at me they enter a letter in a notebook, do not work in combination
I didn’t get you…Can you please explain briefly.
@MahalingPatil
variable = “lahfslhlfahkhbv;jvfs;asn;vjas”
my program give me answer “lahfslhlfahkhbv;jvfs;asn;vjas + AC”
hotkeys don’t work
selectors correct
Which version of UI Path you are using??
