Having Problems Connecting my UIPath Studio to my Outlook
@M_F
  1. Is the outlook licensed? Or unlicensed? It works only with licensed outlook
  2. Does the inbox folder has any other charqcters also…try to click rename and copy the exact name if there are any special characters add those also in name
  3. Try to use OutlookName\Inbox and check if it works
  4. Also try to give the account name if the above does jot work and then try
