Hi, I want to read an unread email from outlook and i designed a flow for that but issue is its reading mail from other not from Focoused. see below screenshot. I want to read email from Focused.
Hi @Puneet_Singh3 ,
Could you try Specifying the Account which you want to read the Emails from, specify in the same way as mentioned in Outlook :
Strill after mentioning account its reading from other not from focused.
try checking with other account and see if issue still persist
normaly after passing account name it should read
I already did its reading OnlyUnreadMessage and folder name is Inbox. Dont know why its reading mail from others
Hello @Puneet_Singh3 , I think this information may help you
We have property in Outlook to get the value focused or Other
Property Name - inferenceClassification - The classification of the message for the user, based on inferred relevance or importance, or on an explicit override. The possible values are: focused or other.
As an intermittent solution can you do as below.
Right click on the Focussed tab->Disable Focussed Inbox.
Please try like this and update here.
