Extracting specific info from Email body into excel
Hi all, I am a beginner to UiPath, May I know is it possible to extract specific text or section in Email Body and stored the relevant info into the excel or consolidated into data table?
Given the constraint that, the emails has multiple correspondence.
Hope to get some enlightenment from the Community :slight_smile: :grinning:
@Juliani_Luo
Welcome to forums
If you have any specific anchor(Keyword) in your Email body to capture then you can use Regex expression and extract the content
Hope this helps you
Thanks
