Exporting data from Power BI to Excel using UiPath
Anyone who could help me figure out what to do?
I cannot use the click activity to export a report due to if the UiPath tries to get that icon/image needed, then it will disappear.
I also tried the mouse scroll but its only getting the 1st 33 rows
Regards and thanks in advance,
Lainy
Hi @Lainyvi_Santoc ,
Could you share a screenshot of your problem statement, and the issue you are facing.
Geetishree Rao
thank you for noticing my question.
Here’s what I’m saying, whenever I use the click activity to click on the 3 dotted to export data, then it will suddenly disappear.
I just print screen it so that you could view it. but in reality, after hovering it to that specific place or area, the UiPath, cannot recognize it. it will disappear.
Could you inspect that element and get the id…So that either from Ui Explorer we can find that and call a click event.
Refer this as well if it helps and you can use hover property to get the click option:
thank you for this @gRao
The problem is I need to have an admin access… :frowning:
