l.stix
(Lisa)
January 14, 2021, 3:59pm
1
We have a problem with our edge extension. We tried to install und uninstall it several times but the extension does not work. It is not possible to select any field in the browser but only the whole browser window. Could anybody help us?
wasea
(Vasile)
January 14, 2021, 6:37pm
2
Hello @l.stix ,
Do you get any specific errors?
The Extension is enabled?
On any sites you have the same behavior?
The same site that you tried in Edge, it is working on Chrome?
If you’re using In Private option?
Vasile.
wasea
(Vasile)
January 14, 2021, 6:39pm
3
Or maybe it’s related to windows updates, as explained here:
Hi folks,
I had to develop a code with EDGE (thing I don’t like at all but I had to do it). The process worked perfectly for months, and there is no errors in the code.
But this evening, the robot was working fine for 3 or 4 hours the process, and at some hour, it just failed, and the reason is cannot comunicate with the Edge browser (uipath says i should check extension)
After instal and reinstal and reinstal de extension, try with different kind of webs, and whatever, the EDGE extenson is j…
