abdel
(Robot usa)
1
Hello Friends,
It seems that after updating Studio to 2020.10.04, the EDGE Extention doeas not work.
i had uninstalled that version and installed 2020.10.0, and i m able to install the edge extention.
is the extention automatically deseppear when there is an update ?
Hi
I hope you are using community edition
In that case try reinstalling Tripathi
Where we will be getting an option to chose CUSTOM one
Click on it and it will take us to next tab where choose AUTOMATION DEVELOPER option and install it
If any of the above didn’t appear it’s still fine
Reinstall the application and give a try
Make sure while installing extension edge application is closed
Check for this doc on troubleshooting
Cheers @abdel
