I have many scripts that both myself and others have developed based on IE. I need to update all of them to use MS Edge as IE will sunset soon. Is there any quick way to do it?
I do know that if attach windows are used, we can just update the selectors to edge and the rest of the activities within the attach window should inherit its edge selector too. However, when I tried it, the attached window selectors is updated and working ok but for the activities within the attach window, they still need to be re-updated 1 by 1 manually to inherit.
Also, some of the scripts do not use attach window too which can be a problem.
Is there a quick and fast way to update the script to be Edge compatible? (e.g. XAML converter etc.) ?
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
