Click activity does not click accurately
I facing a weird issue that the click activity in UiPath does not click accurately at the center of the button (CursorPosition had set to Center) then cause the BOT does not click the button (I had block the user input keyboard and mouse). When highlight the button the highlight also does not highlight at the middle of the button.
Please help me on this, i am new in UiPath
Error:
Screenshot when highlight:
Screenshot for when clicking the button:
Environment details:
Studio Pro 2020.4.1 - 5/8/2020
Microsoft Windows 10 Enterprise 64-bit
.NET Framework Version 4.8 or later
“dependencies”: {
“BalaReva.Excel.Activities”: “2019.1.3”,
“BalaReva.Externals.Activities”: “4.0.3”,
“Microsoft.Activities.Extensions”: “2.0.6.9”,
“UiPath.DirectorySearch.Activity”: “1.0.0”,
“UiPath.Excel.Activities”: “[2.5.4]”,
“UiPath.Mail.Activities”: “[1.4.1]”,
“UiPath.System.Activities”: “[19.4.1]”,
“UiPath.UIAutomation.Activities”: “[19.4.2]”,
“UiPathTeam.File.Activities”: “1.0.4”
It’s better to use Simulate Click option (or SendWindowMessage), if it works. So, for now, can you try to use them?
HI @weiquan.cheah
Try tuning your selector with different attributes and check once
Regards
Gokul
Hi @weiquan.cheah,
Maybe it’s because the resolution, you can try with different properties value in click offset and make validation to run in different resolution
Hi Yoichi,
Thank you for the information, it works by using the simulate click option.
Thank you
Thanks for reply, ensured several times, finally solved by enabling simulate click.
Due to this bot will use in different environment, not prefer to set and offset. Thank you for reply
